Drag and drop Images into Multiple Targets
I want to alter the NI example "Drag and Drop - Multiple Data Types to Start Drag" to use multiple image Targets.  The current VI only allows for dropping image into a single Target.  I want to duplicate the target window a few times, in order to drop different images into each different Target.  I can't seem to figure out how the VI recognizes and differentiates the Targets.
Labview 2009 SP1
(2,937 Views)
Please see attached... That's a simple way to perform what you need : each target is handled in the same event case (the target is differentiated by using control refnum).
Hope this helps,
J.
(2,918 Views)
Thanks a bunch.   That is a very eligant solution.  The only issue now is that when I hover over the new Target Destination, it doesn't show the arrow and the plus folder; it shows the circle with the line through it (the NO, or DO NOT circle).  Not a huge issue, but could confuse the end user.
(2,908 Views)
