Drag and drop from a Mixed Signal Graph to another?
Using a Mixed Signal Graph a trace can be dragged from a plot area and dropped to another one in the same Graph.
Is there a way to have the drag and drop working between two different graphs?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,029 Views)
Hello Vix,
If you would like to associate more graphs together, why dont you just add another plot under the same mixed signal graph?
It is the same thing, isn't it?
I believe that's why it is not possible to do it with different graphs.
Antonios
(2,996 Views)
Hi Antonios,
when I need some graphs one under another I use different plot areas, and this is perfect.
But when I need 4 plots forming a 2x2 matrix, the only solution I think to is two MSG side-by-side (each one with 2 plot areas).
I know there is the XY Plot Matrix, but it doesn't have the capability to drag and drop the traces from a plot area to another!
I think this is the best graph feature available in LabVIEW, but unfortunately only the MSG has it (as far as I know).
Vix
Using LV from 7
(2,984 Views)
