Dragging over a Subdiagram Label breaks drag-and-drop from Project Explorer
This bug has proven to be perfectly repeatable on my system. I'm using the LabVIEW Core 3 Course Project to reproduce:
1. Open the block diagram of a VI with while loop or case structure whose Subdiagram Label is visible.
2. Drag a VI or control from the project explorer onto the block diagram.
3. Drag the VI over a Subdiagram Label, then away from it.
RESULT: Object is ready to be dropped until you drag over a Subdiagram Label; after this the object cannot be placed, as though it is always in an invalid location. See attached pictures.
I'm using LV 13.0f2
____
Ryan R.
R&D
(3,608 Views)
Very repeatable.  Has this been reported?
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(3,575 Views)
I've seen this too in that exact same project!
I will investigate and follow up on this post.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(3,552 Views)
Thank you, Craig! In the meantime I will practice my flanking drag-n-drop programming strafes on block diagrams protected by bulwarks of Subdiagram Labels!
____
Ryan R.
R&D
(3,527 Views)
Sorry for the delay, I was out teaching for a while.
I have filed CAR 449383 documenting this issue.
(3,457 Views)
