Drawing Graph in Excel
I have a template for excel to follow, and I am supposed to draw a graph onto the template using Labview Report Generation Toolkit VIs. However, it keeps returning error  - 2146827284. What am I to check? This error is no longer there whenever i removed all the graph VIs. If I purely just ask Labview to send data to excel at specific locations of excel template, there is no error. Once I initate the plotting of graph, error exists. Do advise.
(3,497 Views)
The following attachment shows the configuration.
(3,495 Views)
Just curious if you ever found the reason for the error.  I am doing something similar with excel templates and getting the same error.
(3,300 Views)
