Drawing line with mouse clicks in picture indicator
Completely different approach:
Load it into imaq image control, draw line roi, get roi coords.
No hardware, no image processing, do not need imaq license.
Message 11 of 21
(3,063 Views)
Hi AS,
Thanks for the idea. Questions:
1. Do I need the Vision Module for that?
2. I guess I need Mouse Events again?
3. Can I use IMAQ with WebCams as snapshot source instead of files?
Message 12 of 21
(3,055 Views)
Guys,
Thank you for the help, this is working already 2 days :). However, I cannot get rid of the flicker - the JPG has to be inside the event, and due to the while loop refresh of the picture control.
Any ideas?
Thanks in advance,
Message 13 of 21
(3,013 Views)
Please post the VI you are using now along with any data we need to see what is happening. Things like flickering images can be very hard to diagnose from a verbal description. With the VI someone can probably guide you in the right direction quickly.
Lynn
Message 14 of 21
(3,007 Views)
OK, here it is, basically Altenbach's VI with a sample JPG...
Message 15 of 21
(3,003 Views)
I do not see any flicker.  Can you provide a more detailed description of what you see and what you are doing when you see it?
Lynn
Message 16 of 21
(2,996 Views)
Accepted by topic author golubovski
(Posting by phone, cannot look at your code)
Right-click the picture control and make sure "advanced...smooth updates" is enabled. Mine flickered before I did that.
Message 17 of 21
(2,988 Views)
Thank you all, especially Altenbach!
Smoothing updates solved the issue!
Message 18 of 21
(2,962 Views)
Minimum is vision acquisition software, NI IMAQ part (not Imaqdx).
Yes. The difference is coordinates are not important. There is no event "ROI change" for the image, you need Mouse up event and check if ROI has changed
That what it is designed for: read camera and show it on the image indicator. But it is IMAQdx (423$ license) or third-party software.
Message 19 of 21
(2,937 Views)
There are a few things that might help you to simplify the code.
For example you could get both the distance and angle from the complex number by just splititng it into r and theta (and convert to degrees) using complex to polar. (The original "abs" just gets the r alone).
There is also the two input inverse tangent function that gives you the full 360 degrees range for the result.
Message 20 of 21
(2,925 Views)
