Drawing several 3D lines in one graphic?
In principle my problem seems easy to solve. I know how to create the 3D graph,and how to set the number of plots available on the graph. My question is how do I specify "These data is plot1, these plot2..."? Cos all the data I put into the graph is represented in plot1.
Thanks in advance.
(2,576 Views)
The following example draws 2 different plots on the same 3D graph (you have to specify the 'plot number' input to the '3D Parametric Graph' VI).
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/96d968d612f01e8586256a9d007614bf?OpenDocument
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,576 Views)
