Drawing user defined rail in 3-D scene
i am done with drawing rail and wheel motion in 3-D scene display on labview.The next step, in my assignment, is to draw the user defined rail(Which will have Y
&  Z axis values) instead of straight line.Can anyone please help me.
i am attaching the vi which shows the wheel motion on straight line.
nitin
(2,817 Views)
one clarification, by Y & Z axis parameters,i mean to say that  one portion of rail can be straight line ,second may be up or down from x-axis or curved along the z-axis.
(2,814 Views)
That is very impressive actually!  Great job!!
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
(2,789 Views)
Do you mean the rail must follow a parametric curve? In that case, you'll have to calculate points at a required interval (e.g. so that it looks smooth) and draw lines between these points.
Wiebe.
(2,765 Views)
