Driver datasocket for labview 2013
Hi
I searched the link to download the datasocket drive for labview 2013, but I did not find it on the NI website, does anyone have this link or do you know if it is necessary to make a request to get it?
(2,783 Views)
Hey GCSilva,
When you install LabVIEW, Datasocket usually comes with it. In case you could not check DataSocket for installation you could review the installer. Other option would be installing the Run-Time Engine, as stated by the KB article below.
Installing the Latest Version of DataSocket and DataSocket Server
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NFLSA2&l=en-US
Try it out and let me know if that worked.
Sincerely,
Felipe Flores
Technical Support Engineer
(2,747 Views)
It worked out your tip.
Thank you!
(2,745 Views)
