Driver for I/O on paralel port (LPT1)
Does someone know, if it's possible to use paralel port for digital input
and output signals in LabVIEW?
Joe
(3,721 Views)
> Joe
You can do this with the standard functions if you are using Windows 9x
or Windows ME. If you are using NT you need to download an additional
library from ni.com. If you are using 2000 or XP I don't know.
DaveR
(3,720 Views)
"DaveR" wrote in message
news:3D1D9359.7010905@unforgettable.com...
input
> > Joe
I believe 2000 needs the NT fix.
(3,720 Views)
Adam:
Digital line control can be accomplished w/ an OutPort.vi. The usual
port address for a standard parallel port is 0x378 but you will need
to check your PC to be sure. Reading ports is harder because it all
depends on the type of port SPP, EPP, ECP, etc. It also depends on
the chipset used to implement the port when it comes to reading ports.
If you are using a Win NT, 2000 or XP Pro O/S you will need to obtain
or write a kernel mode device driver that will grant you access to
physical memory. There are several available on the web if you search
for parallel+port+program.
I would also recommend Jan Axelson's book: "Parallel Port Complete" if
you need to be able to do more than just set output lines for digital
control.
Douglas D
e Clue
LabVIEW/LabWindows/MSVC/MSVB/TestStand developer
ddeclue@bellsouth.net
"Adam Russell" wrote in message news:...
> input
> > > Joe
(3,720 Views)
