Driver for PM5193 on Labview6.1
I'm searching a driver for a function generator Fluke/Philips PM5193 for Labview6.1. I have found the driver for Labview7 and 8 but not for Labview6.
I'm using a GPIB card and I must use the Labview6.1.
Thank you for your help.
(2,787 Views)
Like you mentioned, the mininum requirements to use the driver is LabVIEW 7.0. As you probably know National Instruments does not maintain or support this driver. My suggestion would be that you try to post this on the DAQ/GPIB discussion forum to see if another customer has developed the driver for LabVIEW 6.1
Warm regards,
Karunya R
(2,758 Views)
OK, i'll try this. Anyway thank you for your help.
(2,754 Views)
