Driver for Stanford Research 830 (Labview 7.1)
 Our lab would like to use Labview 7.1 to control the Stanford Research 830 (DSP Lock-in Amplifier).  I have download the driver for  Stanford Research 830 (Labview 8.0) and translating it into the Labviwe 7.1 form. Now I have met a problem: there is a document named "Error Cluster From Error Code.vi" which I can't translate, because inside it the file "Conditional Disable Structure.lvproj" which only exist in the Labview 8.0 but not Labview 7.1. So could you tell me how to replace the "Conditional Disable Structure" by other "structures"? In the  "Conditional Disable Structure",  could you tell me what is the meaning of "TARGET_TYPE==PocketPC||TARGET_TYPE==PalmOS||TARGET_TYPE
==Embeldded"?
(3,104 Views)
Hi Lin,
you always have the option to use the online help for LabVIEW to read about LabVIEW functions. When you're able to opne those LV8.0 VIs you should also be able to read their context help!
As long as you don't use those "Pocket PC" or "PalmOS" cases you can forget about them!
(3,100 Views)
Thank you!
(3,092 Views)
