Driver for USB Power Meter U2002A
I need to implement a test using LabView and a power Meter Agilent USB U2002A, but I can't find the drivers over the net. do any body has?
thank you guys...
(3,536 Views)
I'm not 100% sure, but it seems that based on the documentation the device conforms to the USB Test and Measurement Class. This means you can use VISA and use it as a message-based instrument. Have you tried to see if MAX recognizes it? If so, you should be able to open a session to it and try a simple command like "*IDN?". The MAX session should also show you the VISA resource name to use in the LabVIEW code. It will be something like "USB0::...".
If the above works, then you would need to write a set of VIs for it. However, based on the command set it seems that it programs very much like a regular power meter, such as an E4419. So, you may be able to pilfer the VIs from the instrument driver from that.
(3,531 Views)
go to the following link you will find the driver...
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=17871
Husnain Taseer
Telecommunication Engineer
(3,255 Views)
