Driver install don't detect Labview 2013
After installing Labview 2013 (32bits) , installing driver (Daqmx,etc...) (DVD feb.2013) , application driver don't detect labview 2013, and doesn't want install anything.
Do you know this problem ? and how can i fix ?
Thanks.
Ludovic
Windows 7 32bits
Labview 2013 Eng 32bits
Devices drivers DVD4 feb.13 (also try with Aug12 version)
(4,837 Views)
LabVIEW 2013 didn't exist in Feb. 2013, so the device driver DVD from then won't recognize it.
You need to download the device driver DVD from August 2013.
(4,814 Views)
Hello Ludovic,
In February 2013, you could have access to LabVIEW 2012 SP1.
Now in August 2013, you can have access to LabVIEW 2013:
Julien De Freitas
Applications Engineering Group Leader / Certified LabVIEW Developer (CLD)
National Instruments Switzerland
(4,782 Views)
Thanks for answer,
I can't find link for download devices drivers August2013...  Exist ?
(@Julien..) Your download link is Labview 2013 download application, but don't contain drivers (i.e. DaqMx)
In other link for download Labview (2013), ( https://lumen.ni.com/nicif/confirmation.xhtml ) recommended download devices drivers is August 2012 ... (https://www.ni.com/en/support/downloads/drivers/download.ni-device-drivers.html#327633)
Best regards
Ludovic
(4,775 Views)
Hello.
Try  ftp://ftp.ni.com/support/softlib/driver_cd/aug_13/
Cheers.
Alipio.
"Qod natura non dat, Salmantica non praestat"
(4,769 Views)
Thanks for links ! Smiley Happy
Download in progress.... ,
I will give report...
Best regards
Ludovic
(4,764 Views)
OK now for labview 2013 with devices drivers aug.2013
Thanks !
Ludovic
(4,731 Views)
