Driver subVIs in one folder works but not the copy of it in a different folder doesnt work.
So sorry for wasting all of your time. It was completely my mistake and I found out what my mistake was. There were two slots of NI 2352 switch matrix in the PXI chassis. So when I was copying from the original program I was using the right slow. But when I was programming on my own I was using the wrong slot. That is why it was not working. Sorry guys and thank you.
Message 11 of 14
(515 Views)
All the wisdom learned here regarding where the drivers should go and why still apply here, though.  If it's possible to do - and I understand it may not be your choice - try to follow it.
Bill
CLD
(Mid-Level minion.)
Message 12 of 14
(510 Views)
Yes thank you, I will do that.
Message 13 of 14
(505 Views)
Could be worse!
<Sea Story time>😷
Back in my Navy days I was an Electronics Technician.   You wouldn't believe how often we got awakened at O-Dark:30 to "Repair" something that was "Broken" only to find that the "On Normal / On Full Force" switch was engaged in the OFF position.  And yes, that's how we wrote up the repair report, "XYZ Unit found on full force *** Switched to on normal."
Message 14 of 14
(496 Views)
