Driver to communicate between LabVIEW and Omron CJ1G PLC
I am trying to communicate between my Omron PLC (Model CJ1G) and LabVIEW.  I want to be able to read specific registers and be able to display and save the data in LabVIEW.
I have the "Idustrial Automation Servers for OPC" CD but my PLC model no. doesn't appear under the Omron options.
What other options do I have?
Thanks, in advance,
Felipe
(3,433 Views)
Hi Felipe:
I checked in our PLC compatibility database and the only Omrom PLCs that are supported are the following: C20, C200, C500, C1000, C2000, CQM, and CPM1.
The PLCs that are suppored in the IA OPC server is based on the driver dll that was supplied to us by Omron. When newer PLCs are released, they are not included in this dll and are thus not supported. You might want to contact Omron to see which OPC Server supports that PLC. You should be able to use any 3rd party OPC Server to work with DSC which will then be the OPC Client.
Hope this helps.
Best Regards,
Jaideep
(3,411 Views)
