Drivers for AxD convertor
I use a PowerLab AxD conversion unit that connects to a PC via SCSI.
I would like to write a front end application for this using LabVIEW but
there are no drivers available for this unit and the AxD manufacturer is not
interested. What steps would be involved in constructing my own drivers for
use in a Windows enviornment.
Any help would be appreciated.
(3,191 Views)
If there are DLL type of drivers available then you can write LV VI wrappers
for those DLLs. Ideally you would write CIN wrappers to those DLLs then
write VIs to call CINs. Advantage of CINs is that sometimes there are
problems with pointers to arrays if using a LV DLL wrapper. Basically if
there is not enough memory LV could reallocate the memory locations passed
to the DLL before you have retrieved the data. So I would get driver API
from the manufacture and write VI's to call manufacturer's DLLs assuming
that they are available.
Reinis Kanders
"billbo" wrote in message
news:396306aa@pink.one.net.au...
s using LabVIEW but
not
for
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 80,000 Newsgroups - 16 Different Servers! =-----
(3,191 Views)
[posted and mailed]
billbo@cyllene.uwa.edu.au (billbo) wrote in <396306aa@pink.one.net.au>:
>not interested. What steps would be involved in constructing my own
>drivers for use in a Windows enviornment.
If you know enough about SCSI, our company provides (sells) a SCSI
toolkit for LabVIEW but you will need to understand the SCSI conventions
and have a detailed knowledge of the SCSI command block structures that
the device uses to communicate. SCSI at any stage is not for the
fainthearted. For specific hardware this will
mean obtaining the command
block structure directly from the provider.
Out of interest I am not aware of the PowerLab AxD. Is this an AD
Instruments PowerLab or some other manufacturer with a coincidental name.
BTW we also have a LabVIEW driver for the PowerLab E Series and we are
located around the corner in Vic Park, Perth.
Alexander C. Le Dain, PhD
ICON Technologies Pty Ltd
http://www.icon-tech.com.au
(3,191 Views)
