Drivers for C6713 DSP
Hi
I was using Code Composer Studio for Programming the TI DSP C6713, however, I have learned that Labview offers an easier and more efficient alternative. So can some one please tell me what are the requirements to use Labview. Which toolkits should I have? More importantly as I was going through some demos, I found out that some drivers are required to interface
So, which drivers are required? Where to get them
(4,314 Views)
Hope this thread will solve your problem.
Post back your proceedings.
Mathan
(4,304 Views)
Thanks Mathan for guiding me, however, those links didn't really help me, I had already visited them.
I have some more botheration for you, if you do not mind. Let me write my problem, maybe you can suggest a solution
'I am having problems in using Labview with C6713. I installed LW DSP module (core installed already!) and plugged in the c6713 to my PC. Now, when I clicked on the option of connect after creating a VI that takes analog input and fans out the same to analog output, its shows connection error
Does any one know, why this happens.... Isn't LW directly able to support DSP C6713 without Code Composer Studio, so why is it giving an error? I can't understand
I read in one of the tutorials I might have to install drivers for C6713. Now, I don't which drivers are being asked, since they are not listed. I tried to installed the 6713 drivers given in the CD that came along C6713, however, those were for Code Composer Studio
Now, I have found a file "Setting Up the Texas Instruments 6711 DSK Target" I'll try to follow what this files says, but again its for another DSP'
(4,287 Views)
Hi Third Person,
Please limit your questions to one thread. You posted this question on here
http://forums.ni.com/ni/board/message?board.id=170&message.id=439254&jump=true#M439254
Flash
(4,271 Views)
Hi Third Person,
What sort of connection error? Can you post a screen shot? The thread Mathan directed you to had lots of applicable information. Did you go through the links that Daniel posted on that thread?
Matt
(4,270 Views)
