Drivers for LabVIEW 16 or 15
Hello. My name is Egor and Im from Belarus (so excuse me for my English, I write with a translator). I work in this environment for the first time, so much is not clear. My job is to write a thesis for the university. I decided to stop on the version of LabVIEW 2015, but in extreme cases I can switch to 16. I installed everything that seemed to be needed, but I was asked to specify the path for the drivers to make the installation. Below I attached the picture. It shows that the installation has not started yet. And already at 0% I'm asked to specify the path to the drivers. If I press Install Support, nothing happens. Probably, because there are no drivers 🙂 If I wait on Decline Support, then the installation ends at 0% and it comes to me that The NI LabVIEW 2016 (64-bit) installation is complete.  Next, this shortcut appears with the image that is on the picture. And I can not enter it. In this regard, I have a question: is it possible somewhere to find the driver specifically for 2015 or 2016? I would be very grateful if you explain what to do next. In my understanding, you will need to install all the drivers and the shortcut will open? If so, explain which folder you want to install driver data into. Thank you very much
Message 1 of 10
(6,104 Views)
The device drivers are a different download, the latest drivers are linked below.
https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html
If you are installing LabVIEW from DVD's you should have the driver DVD's as well.
The next question is why are you installing the 64 bit version of LabVIEW?  Look at the following link to see if you really need the 64 bit version.
https://www.ni.com/en/support/documentation/supplemental/18/labview-32-bit-vs--64-bit-applications-f...
Message 2 of 10
(6,090 Views)
Thank you. I have read and understood that for convenience really is better to install the 32-bit version. Could you please give a link to it? Because I have only 64, and on the site I do not find it.
I mean LabVIEW 2015...Or I do not know if I need to install LabVIEW 16, because I could not find all the necessary toolkits for it. Especially I needed Modulation Toolkit for 16 version
Message 3 of 10
(6,075 Views)
Go to the NI.com main page and click on the support link at the top of the page.
Under the software header there is a link for LabVIEW.
Then go to the LabVIEW products download link under the NI Products download header.
On the left side under version you can type in the version of LabVIEW that you are looking for.
Then the site will show you the download options for your search.
I think the web installer versions are a little more automated, so it might be easier for installation.
Message 4 of 10
(6,063 Views)
I understand how this works. But even after having done all your instructions, I come across the fact that there are no versions of LABVIEW 2015 here. There are all versions except this one
Message 5 of 10
(6,060 Views)
Well, you might be doing something wrong then because it works for me.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/n1:2015_SP1,n8:28,ssnav:pdl/
Message 6 of 10
(6,025 Views)
Message 7 of 10
(6,018 Views)
So contact NI support or your local rep directly.
I just tried a google search for "NI LabVIEW 2015 download" and it took me to the NI site.  It might work for you?
Or see if these links work.
http://www.ni.com/download/web-based-installer-labview-development-system-2015-sp1/5865/en/
or
http://download.ni.com/support/softlib/labview/labview_platform/2015%20SP1/LabVIEW_Platform_2015SP1_...
Message 8 of 10
(6,006 Views)
Maybe there are some bans on downloading from another country, I do not know. Decided to stop at 2016 32 bits. And the last. You can give a link to download all the necessary Toolkits? I somewhere found some, but I'm also interested in Modulation Toolkit which was not there. Can you know where they are all in one?
Message 9 of 10
(5,980 Views)
Good. I found some toolkits separately. But for a non-English-speaking person it's difficult to find the entire list of the toolkits. Therefore I installed only those that my friends installed. Please give a link to the list of all the toolkits for LabVIEW 2016?
Message 10 of 10
(5,969 Views)
