Drivers
I need this file: DAPIO32.dll, and the drivers for the card NI-DAQ PCMCIA 6024E
Maria
(3,091 Views)
The 6024 is supported with both DAQmx and traditional DAQ. I would recomend DAQmx. I'm not sure what DAPIO32.dll is. If you have a board from a vendor other than NI, then you need to go to that vendor's web site and see if they have the driver available for download.
(3,079 Views)
Maria,
there are no Stand-Alone drivers for the DAQ-device. The drivers are included in a driverpackage called NI-DAQ. This is available in two different versions: traditional NI-DAQ and NI-DAQmx.
The NI-DAQmx is the newer version and i advice you to use it unless you want to run an existing program with the device which is using the old NI-DAQ (trad.).
You can download NI-DAQmx here.
hope this helps,
Norbert B.
Message Edited by Norbert B on 01-22-2007 09:38 AM
Norbert
Expert: Geometry
(3,078 Views)
