Drop-down box used for searching through an Excel file
I hope this problem isn't too difficult, but basically I have a 1D array in a *.csv file (need.csv) and I'm dumping its contents into an array which I'm converting to a drop-down menu using the Ring function.  This is done sucessfully.
I also have a 2D array in a *.csv file (delivered.csv) that will be searched through when a particular value is selected from the drop-down menu.
The problem I am having is the only value it's looking up is the first element in the drop down array.  If I select any other element in the drop-down menu, LabVIEW doesn't search and return the information corresponding to element i looked up.
If it helps, I modified the example, Search 2D Array.vi, created by tst.
I am attaching my VI, as well as files used for my VI.  They are *.xls files, so you will have to save them as *.csv files because this forum doesn't allow me to attach *.csv files.
If you need clarification, please let me know.  I'll appreciate ANY help.
Thanks 🙂 ,
Amal Patel
(2,938 Views)
Try this and see if it will work for you.
Joe.
"NOTHING IS EVER EASY"
(2,917 Views)
This works beautifully!!!   Thank you very much!!!
Amal Patel
(2,913 Views)
We say thank you around here by giving good ratings.
Joe.
(2,908 Views)
