Drop down menu to populate fields used for testing
If you need totally different test parameters for each test, instead of displaying a cluster with identical parmaters, I would use a table. The row headers could be populated by reading an ini file. The table is a 2D string array that would be passed to each test subVI and each subVI would have to know what parameters are being passed to.
Message 11 of 12
(456 Views)
I think you are right with the table for the different test parameters,
How the latest example runs is in fact what i was after.  I will be running the same test every time, but what changes is what i will be testing.  each specimen has slightly different values, such as lengths from the manufacturer for the same thing and i want them to be all in there when the specimen part number is selected.
Message 12 of 12
(450 Views)
