Dsp Processors with Labview Support
Greetings,
I am looking for some Good DSP Processors for Image Processing Applications for Personel use.
can anyone suggest me a good Processor Board Supported by LV that is quite economical.
I have seen some processors from NI that is quite expensive for personel Use and not affordable for students .
Sundar.
(3,355 Views)
Hi Sundar,
Are you using LabVIEW DSP module?
The LabVIEW DSP Module currently supports the following four DSP evaluation boards:
  • NI SPEEDY-33
  • Texas Instruments TMS320C6713 DSK
  • Texas Instruments TMS320C6711 DSK
  • Texas Instruments TMS320C6416 DSK
Refer to LabVIEW DSP Supported Hardware Targets for more details about these evaluation boards. Currently, the LabVIEW DSP Module does not support custom DSP hardware even if the hardware has similar or identical peripherals to the supported targets listed above.
Stanley Hu
Applications Engineering
http://www.ni.com/support
(3,327 Views)
Duplicate Post.
Please don't create a new message thread with the same question.  It causes multiple responses from people who may not have seen the other thread.
(3,305 Views)
