Dual/Multiple I2C hardware
I need to have two I2C/SMBUS devices in my System. I see 8451 has only one I2C module, is there anything with Dual I2C modules. I don’t want to invest my 2 USB slots if it can be done in one. Can anyone share the sample LabVIEW VIs for I2C slave?
(2,495 Views)
Accepted by topic author NG2202
1. You will actually need the USB-8452 to do I2C slave.
2. There is a decent example in LabVIEW (Help->Find Examples).
3. You may be able to use the same I2C device, just looking for multiple addresses.  I will not promise that as I have not tried and it has been a couple of years since I did look at simulating an I2C slave.
(2,438 Views)
