Dual Numerical Control Change
Dear Friends
I have two Numerical Control in the FrontPanel. Now I want to program Numerical Controls such that when I changed one of them the other one change susequently.
for example in the attached VI when I set "A" to 1 "B" should be automatically 1 to and when I changed "B" from 1 to 5 "A" Should be changed to 5 automatically.
Sincerely V.S
(4,467 Views)
Hi VS,
use an event structure and a value change event for each control…
(4,461 Views)
Dear GredW
Could you please explain more?
Regards
(4,435 Views)
Accepted by topic author V.S
Hi VS,
that's what it looks like for a value change event of "A":
Btw. is it that hard to spell my name correctly?
(4,428 Views)
Dear GerdW
So sorry for misspelling
Thanks for the solution.
Regards
(4,416 Views)
Dear GerdW
The suggested solution works but when I change the data several times in a row it hangs and I can not input new values any more.
Please see the attached file.
Regards
(4,408 Views)
Hi, V.S
You have too much event structure in while loop.
It will run step by step.
For example, when you change value A , and it will run "A" event but the last three event wait for user changing value.
The program is not to work, because it wait others event occurs.
You can add more case in one event.
Patrick
Certified LabVIEW Developer
(4,396 Views)
