Dual Slide Properties Set in Case Structure
Hello, My objective is to change the properties of a dual slide indicator depending on the value.  I have a target value and actual value.  If the actual value is greater than the target, the fill is green between the target and actual values (fill style=3 to value above).  If the actual value is less than the target, the fill is orange between the target and actual values (fill style=4 to value below).  I am able to accomplish this by selecting properties on an individual slide, however, when I use a case structure and property nodes, the result isn't what I want.  A simple example is attached.
Also, is it possible to set properties of Slide 1 and Slide 2 in the property node?
(4,902 Views)
Can't try your code.  Missing subVI.
(4,880 Views)
(4,871 Views)
Accepted by topic author stacey54
You have to set the fill style for both sliders.
See attachment.
(4,857 Views)
Perfect.  Thanks!
(4,850 Views)
An XControl would be alot closer to "Perfect"
(4,838 Views)
Somewhat related to that, here is an XControl that's a vertical pointer slide with a readback indicator.
The pointer shows the selected value, and the fill shows the value read back (there's an example of use in the .llb).
(4,780 Views)
