Dual monitors in LabView/W98
I would like to know if it's possible to display a vi on two monitors (one
chart on the first and another one on the second) ?
(3,612 Views)
Yes. The following companies made multiple monitor video cards as of 1999.
We use the Appian Jeronimo Pro. The Colorgraphic Predator has good specs,
but were out of stock when we ordered. These links are old, but they should
get you started.
Colorgraphic. Predator. http://www.colorgfx.com/predator3d.html
STP. MVP Pro-128. http://www.stbmvp.com/multi.html
Matrox. Productiva G100MM.
http://www.matrox.com/mga/products/productiva_g100_mm/displays.htm
Appian. Duet and Jeronimo Pro. http://www.appiantech.com
Dan.
"Francois Nunio" wrote in message
news:98quou$s62$1@netserv.univ-lille1.fr...
(3,612 Views)
& you could use second graphic card [i suppose PCI card] - win98 will find
this.
It could be cheaper than multiple-monitor card like Matrox, but it will be
problem find now PCI graphic card.
best regards
Dedal
U¿ytkownik "Dan" napisa³ w wiadomo¶ci
news:Lv7s6.666$bo6.137373846@newssvr10-int.news.prodigy.com...
1999.
should
> get you started.
> Dan.
(one
(3,612 Views)
I am using the predator pro AGP from colorgraphics that supports two monitors as a single desktop. I have used multiple cards in the past to support 10 monitors each with a separate VI in it.
Stu
(3,612 Views)
Hi Francois,
yes this is possible, last year i developed a labview program for
windows 98 which displays serveral windows on two monitors. The
personal computer we have used was equipped with two
ATI graphics cards (One AGP and the other PCI). We have used this
configuration to record the contents of one screen on a
video tape.
best regards
Günter
(3,612 Views)
