Dual scales- How do I designate which (Min Max)attribute node goes to which "Y" scale?
Labview 6.i front panel with a chart, multiple plots, several transducers, thermocouples, Vdc, power monitors.
I need a dual "Y" scale for a new application. I had no problem making the duplicate scale and designation which plot goes to what scale, however, when zooming in on a section of the plot and then resetting the chart with the minimum and maximum scaling attributes, it only resets the "0" scale ( -30 to 500) not the "psig" scale (-300 to 5000). How do I designate which (Min Max)attribute node goes to which "Y" scale?
I will be upgrading to 7.1.1 this week, is a new tool available to do this? Thanks
(2,946 Views)
Hi Scott
There is a property called "Active Y scale" to select the scale you want set min,max, etc.
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,944 Views)
thanks for the reply, is the node expandable? Should I change the name of the y plots to a specific name or number? I am upgrading this week so 7.0 and 7.1.1 tools are new to me, i still have to conver some of my old panel and sub vi to new. If the scale factor for minimum and maximum for the specific Y scale is designated at start up, would the default values be over written? thanks scottyd
(2,943 Views)
Hi
Download example about scales.
:ni example
See attached doc. Once you select an y active scale, all Y scale modifications affect that scale.
It works like select active cursor.
Cheers
Alipio
(2,929 Views)
