Dumb question: 2D Array?
I'm a total newbie...so brace yourselves! 🙂
I see that I can take an array container and dump a string in it in
order to make a 1D array of strings. So, how do I make a 2D array.
Thanks in advance...
-- N
(3,211 Views)
Borland C++ 5 Builder (for example)
DynamicArray >
(3,211 Views)
In LabVIEW, you can add dimensions several ways. The two that I most commonly use:
-Right click on the array and select Add Dimension
-On the diagram, feed the 1D array wire into a Build Array function, which will increase it to a 2D array.
(3,211 Views)
You can also use Initialize Array function.
(3,211 Views)
