Dummy IMAQ generator from external software
I would like to use a LabView program to handle images generated dynamically by another (non-labview) program.
I don't know the best way to achieve that :
-I could stream images from the external program to the network, and just read the images from the endpoitn in LabView. But I miss the documentation of how to binary encode 2D images with width,height,depth so that LabView can decode them (I cannot encode the images in JPG or PNG for performances reasons, I must keep them as raw bitmaps)
-is it possible to create a dummy IMAQ device that would produce the frames as generated by my external program ? And how to do that ?
-any other idea ?
(2,897 Views)
Will IMAQ array to image work?
(2,855 Views)
It could work if the array was encoded in a legible format by the external program, but I can't find the documentation on the expected byte layout.
(2,843 Views)
