Duplicating odd marker labeling on axis
Take a look at the Y-axis of the plots of signals for the file attached.  These plots are from a third-party vendor and I want to duplicate them in a waveform graph in LabVIEW.
Plot A shows the Y-axis in volts. Obviously, this is no problem if array contains values in volts or voltage range is supplied along with relative values.
Plot B shows a normalized Y-axis from -100 to +100.  I have no problem duplicating based on information from Plot A.
Plot C shows plot in terms of decibels.  My first thought was to just convert values to dB using formula: 20*log(Array Value/ Array Max Value).  Although correct in terms of converting values to dB, it does not provide the desired effect. Plot C really shows that at the 50% point, one is -6dB down from the max (with the max defined as 0 at the top of the plot). The negative portion of the axis labeling is handled similarly.  Any ideas on how this might be done in LabVIEW.
Sincerely,
Don
Message 1 of 17
(4,638 Views)
Hi Don,
As far as I know you can't automatically setup the scale to fit the values that you want. This is simply because you can't calculate the logarithm of a negative number. However, the scale you want is actually a completely simple linear scale that goes from 1 to -1 but it's presented as the 20*log(|y|) where y is the value of the y axis (1 to -1). Since only the representation is changed, you can just remove the numbers from the scale and insert the "0", "-6", etc. strings instead. It will then look something like this:
Let me know if you have problems reproducing this customization.
Have fun!
Message Edited by Philip C. on 11-10-2005 02:37 AM
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 2 of 17
(4,618 Views)
That looks great but can you be more explicit on how you actually accomplished this?  Via a property node of sorts?  I had originally looked at 'marker values' as a possibility but that was a no go.
Sincerely,
Don
Message 3 of 17
(4,606 Views)
ps. or did you literally just create from 2d classic string indicators and recolor to match graph background?....Don
Message 4 of 17
(4,600 Views)
Hi Don,
All I did was choose the Y-scale style that doesn't have marker values and then simply put free text labels at the appropriate places on the Graph. Don't use String Indicators/controls unless you need to programmatically change the strings while the IV is running. I then selected all the labels and the Graph and grouped it all together, so they wouldn't move independently if dragged at edit time.
Very simple indeed!
Thinkbot Solutions
Message 5 of 17
(4,587 Views)
What font set did you get the infinity symbol from (and using what keystroke).
Property nodes can be used that will allow decorations to be visible or not visible, but how about for free text labels?
I need the ability to switch between the different Y-scales I mentioned earlier, and that entails making either graphs or decorations visible/invisible.  Do you see where I am going with this?
Sincerely,
Don
Message 6 of 17
(4,570 Views)
ps. I see you addressed this already; yes that is why I originally thought of the string indicators because I do need to make visible / invisible programmatically.  So I will use those. But again what keystroke and font (symbol?) did you use to get infinity?
Thanks again,
Don
Message 7 of 17
(4,568 Views)
Fully transparent 2D classic control string indicators will work for use with property node visible/not visible....Don
Message 8 of 17
(4,566 Views)
Hi Don,
Good question about the-sign. Well, I used the same procedure as I always use when using "weird" characters; open Microsoft Word, select "Insert » Symbol..." and then find your symbol among the many choices. The -sign can be found used in many fonts under the Mathematical Operators category:
Notice that the symbol is unicode that we don't officially support, so you can't use it in owned labels, enums etc. Also, notice that if you use the value of the -symbol as a string value, you will get in trouble when passing it to a string indicator (what did I just say; unicode is not officially supported in LabVIEW - I warned you, right?):
Well, I guess you can get some acceptable results if you don't pass the value to the indicators. And just a note; you CAN indeed get the reference to a free label and thereby control its properties - but it requires the use of VI Server which means a lot of additional programming for you. However, there are example programs out there that shows this feature if you are interested.
Have fun!
Message Edited by Philip C. on 11-15-2005 07:43 PM
Thinkbot Solutions
Message 9 of 17
(4,560 Views)
Hi Phillip:
Thanks for your help on this one.  Now that I know where to find infinity I should be all set.  I'l figure out what the best way to display it is.
I know all about VI server, been using it for years to access/set control/indicator properties.  And I believe I've used it to access visible/nonvisible property for decorations.  Just was not sure one could do the same for free text labels so if I use those, I will figure out how to do this as well.
Thanks again,
Don
Message 10 of 17
(4,535 Views)
