Duration and pause of signal
Hi all,
      I’mnew to LabView and I need help. In my experiment I’m  use one generator Agilent 33220A and oscilloscope DSO6014A. The Generatorconnect to PC with help GPIB-PCI.  All   I want is generate  signal (it can be sine) and be able change , frequency,the duration of signal, pause between two signals, amplitude and waveformfunction)   and save date in file *** .csv   with help oscilloscope
            For example a want to generate sinesignal duration 2 seconds and after that a need a pause duration  1 second.  Or signal 1 second – pause 3 second.
Please, help mi programming it.
(2,925 Views)
A state machine architecture may work for you, your enum could read "wait 2 seconds", "wait 1 second", "wait 3 seconds"
there are tons of examples on this forum and in the example finder on state machines.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(2,914 Views)
I hope this helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(2,913 Views)
hello,
        thanks for you  answer, but it's not help mi.  please, help mу create this VI. I want  For example a want to generate sinesignal duration 3 seconds and after that a need a pause duration  1 second.
Thanks for help.
(2,890 Views)
