Hi Wolfgang,
Yes I was thinking of PWM for the duty cycle control. I have done this before using counters on the NI cards, but as you mentioned it is only possible to control 2 signals. I now need to do at least four, possibly more. The system I am using now is a 6036 PCMCIA card as acquisition connected to an SCXI 1000 with an 1102, 1126, 1163R and 1124. I have considered using another DAQ card to provide more counters, but this is a very untidy solution when you have two PCMCIA DAQ cards in one notebook each with a cable going into it. The connectors push very hard against eachother and in long term use, this will destroy the connectors on the cables, the cards and the notebook.
I gather that there is no SCXI module available that provides counters as a normal "slide-in" module (like an 1102 for instance)...? Is there then some other effective way to connect two PCMCIA cards to one notebook?
Thanks for the advice on the counter cards.
Regards
Charel
