02-10-2006 02:34 PM
02-13-2006 10:30 AM
02-13-2006 05:02 PM
I am still having a trouble with setting duty cycle value above 35%...
Tried to add timebase mode subVI in the application function VI, but the outcome is still the same.
Plz help on this...
02-13-2006 05:02 PM
02-14-2006 10:55 AM
HI Matt_S,
Thanks for your response!
1. Could you please explain how I can use a single frame sequence to prompt a user as soon as the main VI gets started?? Do I need to use 'stacked sequence structure' (?) where do I have place this particular sequence frame?
2. for ext trigger w/ duty cycle..I can set the duty cycle value up to 34%, but for values 35% and above...instrument shows 0.5% for all values...there is No Error message either from instrument front panel or the VI error out cluster. I can change duty cycle value manually when swtiched to local setting...so I suppose that it should work any duty cycle value between 0-100%....(I am confused how to approach this problem)
Best,
02-16-2006 11:00 AM
02-16-2006 01:13 PM
Thanks Matt_S.,
I started the new thread in the instrument control board...hope to find a better luck with answers...
I switched the order of concatenation of string in 'hp8133A_Ex-Div Timebase__mod.vi' and it works fine now.
I suppose that an order it passes different string value makes a difference(?)
02-16-2006 04:40 PM
