Dynamic Data Attributes Not Transferring to Diadem
Attached is a screenshot of my program in which I am trying to save multiple dynamic data signals to a binary TDM file. The first signal is an indexed DBL numeric converted to dynamic data. The remainder are concatenated arrays of DBL numeric converted to dynamic data. All have name and index attributes set and merged before being saved to a measurement file. When the file is viewed in Diadem only the first signal shows its name. The remainder are untitled. Can someone help explain why this is happening?
I should also mention that if I take the individual signals (one at a time without merging) they still are unlabeled, except for the first.
Thanks!
(2,562 Views)
Did you try using the Set Dynamic Data Attributes express VI on the wires before merging them?
(2,557 Views)
Yes, sorry if I wasn't clear. In my first attached image the subVI on each of the signal wires is 'Set Dynamic Data Attribute.' I just condensed it down to save space. Each has a unique name and signal index set in the properties menu.
(2,538 Views)
