Dynamic Link Library NIPALU.dll
I am trying to load a VI developed test a circuit board i get the following error:
The dynamic likn library NIPALU.dll could not
be found in the specified path...
I have not been able to find the file anywhere online. How do resolve this problem.
(3,840 Views)
I am not sure what you are trying to do, but it sounds like you are trying to acquire data. If you are using one of National Instruments examples in LabVIEW and you are getting this error, I would recommend reinstalling your NI-DAQ driver. After reinstalling the driver, check in MAX to make sure the device is working correctly and that it passes the Test Resources in the device properties.
I hope this helps out,
Joshua
(3,840 Views)
