Dynamic creation of controls on the fly
I want to populate the labview front panel with controls read from an XML Sheet.
Is this possible in LabVIEW????
At the start , I will read the xml and the depending the controls writen in the XML file i will palce them on the LabVIEW front panel.
This feature of creating dynamic controls is easily avaible in other programming languages like VB .
Please help me if such type of feature is avaible in LabVIEW too...
Thanks a lot in advance
Avni
(3,381 Views)
Hi Avni,
Please try searching these forums for the title "Scripting in LabVIEW" & also the lava.org forums for the same; you ll get a lot of ideas. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(3,377 Views)
Hi parthabe,
Thanks a lot for your reply...
But you have some links then can u please forward it to me.
I have tried searching on lava also and Scriting in LabVIEW, but i was not able to get any useful info...
Please guide me if you some info on this.
Avni
(3,374 Views)
Someone else asked something similar recently here:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=291350
You may find it helpful, and at the least, it's worth a look for a good laugh.  🙂
(3,352 Views)
