Dynamic input
hello again everyone,
I'm not an experienced user of labview so I think it is a simple question:
I'm in fact designing Inputs for a fortran program: I have a combo box with two choices: '1' or '2' and depending on the choice ,I want to have one or two numeric indicator (for further input to appear)that appear
I linked my combo box to a case structure where I have my two cases.
But when I run my VI there is always my 2 numeric inputs appearing from the very beginnig...
I guess I missing something,
If anyone has an idea, it would be very welcome.
kl
(2,961 Views)
You will probably have to place 2 numeric controls on your front panel, but then start with the second one hidden. You can change the properties though a property node for that control. Just be sure the default setting for the second control is hidden.
(2,952 Views)
Thanks mlloyd , it sounds like a good Idea
I'm going to try it.
klaks
(2,933 Views)
