Dynamic objects
Hi Ben,
So like exemple in my interface I have a motor and I want to have it in green when it work normaly and in red when it have a problem.
On the VI below you will find some objects wich I found in an interface. And my aim is to know how can I create objects like that.
Thanks for your help.
(4,163 Views)
Hi Basile21,
these controls are image rings. You can customize them, so that they look like you want.
Mike
Message Edited by MikeS81 on 07-29-2008 09:18 AM
(4,160 Views)
Hi Mike,
Image rings ??????? can you explain me more please !!!!!
(4,147 Views)
Hi Basile21,
yes image or picture rings. You can add pictures there. Use the advanced -> customize function to change the style.
Mike
(4,142 Views)
Perhaps it would be best to have this in the original thread.
To poster: Please don't start multiple threads about the same subject. It's best to stick to the original thread. If you respond, then the people who posted will receive e-mails of a new message.
(4,107 Views)
The problem is that the original thread now points to this one.   A single thread should be chosen for discussion.
R
(4,092 Views)
