Dynamically Adding Plots to XY Graph
Hello!  I hope you can help me....
I am trying to dynamically add plots to an XY Graph in LabVIEW.  For example, pretend I have three plots and want to add a fourth while the program is running.  I know that I could add extra plots and just write blank data until I need them, but in reality I could have over 500 plots (I know, it will look like a mess.  But that's what they want...).  Anyone have any ideas?  Just to be clear, I will not know beforehand how many plots I will need...  and it may change with each run.
Thanks in advance.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,064 Views)
The XY Graph takes an array of plots as input, and can thus easily vary the number of plots at run time, so I don't understand your question.
(3,033 Views)
Followup to Dr.P's comment, I trust you aren't confusing Graph (where you basically write the entire plot each time you update) with Chart (where you write the latest values), correct?
Bob Schor
(2,978 Views)
It's still easy with a chart.  There will just be weird things when you change the number of plots (chart could be cleared, you see disconnects, etc).
(2,971 Views)
how many data points are in one plot? does this vary, too?
what kind of datapoints e.g. double or integer?
I guess, I would use a (named) queue and "get queue status" for displaying
(2,951 Views)
