Dynamically Resize Front Panel Objects Based on Content
Hi everyone,
I wonder if there's a dynamic way to resize front panel objects—such as string indicators—based on their content. For example, I'd like an indicator to automatically adjust its width or height depending on the length of the text it displays, without having to set fixed dimensions manually.
Has anyone implemented something similar or found a workaround for this? I'm working on a UI that needs to adapt to varying data sizes, and I'm trying to keep the interface clean and readable without wasting space.
Any suggestions or examples would be greatly appreciated!
Thanks in advance,
Fabio
(1,607 Views)
Sure, use Get Text Rect.vi
(1,589 Views)
Hi Fabio,
You can determine the (pixel) size of your text by using the 2DPicture functions.
Using this information you can then adjust the size of the string indicator using its property nodes...
(1,586 Views)
Thanks for your reply!
I realize I didn't explain myself clearly earlier. What I'm actually trying to do is adjust the font size of a string indicator dynamically, so that the text fits within the fixed width of my front panel. In other words, instead of resizing the indicator itself, I'd like the font size to adapt based on the length of the content.
Has anyone tried something similar or found a way to achieve this?
(1,570 Views)
Hi Fabio,
You basically do the same steps:
  1. Determine the pixel size of your text using the very same 2DPicture function
  2. When the size fits: goto step 5
  3. Change the font size for the pixel size calculation (increment/decrement)
  4. Goto step 1
  5. Display the text in the string indicator and set the font size used in step 1
Yes.
In your first message you wanted to change the object size depending on the content.
Now you want to change the content size for a fixed object size…
(1,539 Views)
Consider leaving the font size alone for accessibility reasons and allow the user to scroll through the string indicator.
Readable, but incomplete:
Not readable for most audiences, still incomplete
Readable, incomplete:
Generally, I think your UI will be better if you decide how much space you can allocate for each control and indicator, keep a consistent font size, and let the user scroll through text where there is more information than fits in the allotted indicator size.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(1,495 Views)
