Dynamically control plot number of stack waveform chart
I want to use the waveform chart diagramm in stacked view:
In a simple example I cluster the signals and wire them to the chart diagramm ( - 3b.) data preparation chart diagramm):
Is there a way to dynamically change the number of shown plots in the stacked waveform chart?
Thanks a lot and best regards,
Michael
(4,482 Views)
I don't know way to change plots number, but here is way to hide some lines.
But if you change array size, chart will redrawn.
(4,450 Views)
Did you try uisng an array of WF datatypes?
Clusters can only be re-sized at development time.
Ben
(4,438 Views)
Is there an example for that? I tried, but the result was not a plotted line, just many dots.
(4,368 Views)
