Dynamically creating and modifying the front panel
Is it possible to dynamically create or modify UI items in the front panel?  If so, how can this be done?
(3,355 Views)
You can certainly modify existing items on the front panel by way of property nodes.
You can create items on a front panel if you use scripting as long as the VI is not running.  But considering that you seem to be a new LV user, there is no way I can recommend you doing anything with scripting at this time.
Why don't you tell us what you are trying to do, and we may be able to suggest an appropriate way for you to do it.
(3,342 Views)
Relatively new, yes.  I want to create, modify, and delete UI elements (buttons, charts, etc) while the program is running.  Don't know if this is possible or not and I haven't been able to figure out how to do it.
(3,320 Views)
The intent is to allow multiple different UI configurations without having to build the UI by hand for each case.
(3,318 Views)
Please post some screen shots that show us some of the variation and flexibility you want to provide with the app.
Ben
(3,314 Views)
Just a simple answer, as was said above, without scripting you wont actually be able to create objects. You can however place everything on your front panel that you need, then show/hide controls as necessary maybe based on a startup configuration etc etc. As Ben said, you will need to give a more detailed example for what you want to do in order to insure you get the answer you are looking for from these forums.
(3,299 Views)
