Dynamically inserting data to make a report
Hi all, I am facing a problem with report generation. Currently I am making reports using excel templates. I am attaching the picture of sample template here. As you can see B22 is the location of item 1 and B23 is the location for Description 1. Space for description is fixed. Now B30 is the location for item name 2 and B31 is the location for item description 2. My problem is, if description of the item 1 is very small, that already allocated space will be waste.Or if Description 1 is very large, I cannot accomodate it in the given space. So I need item name 2 to come exactly under description 1, rather than fixing the space for item name 2 and subsequent rows. In short, the allocation should be dynamic, according to the size of the descriptions. Is it possible through LABView? Any ideas?
I dont need it to be done with excel only. I need that format of my quotation should be same thats all..Is there any other ways to do this?
Thanks in advance,
Suvin.
Message 1 of 1
(2,487 Views)
