Dynamically loading VIs and getting data from them
Good time of day.
I am trying to write a program that would aquire data from various instruments. I have a large set of driver VIs that would be used for this. Each one of them typically takes one input (GPIB address) and gives one output.
I want to make my application universal: be able to poll all the GPIB addresses, figure out what devices are online, load VI's and start the data aquicison cycle. My question is how would I go about dynamically loading VIs into memory and then running them with parameters and getting some output out of their indicators?
A relevant example would help a huge deal.
Igor.
(2,583 Views)
You load VIs dynamically by using what's called "VI server". The relevant VIs are in the application control palette, and you can find at least a full chapter in the LV user manual and some examples in the example finder (Help>>Find Examples, search for dynamic or server).
___________________
Try to take over the world!
(2,573 Views)
