Dynamically plotting data in mixed signal graph
I am working on a project where I receive a string of numbers continuously from Arduino and then converting the string into a 2D array of x columns (x different data) and n number of rows which gets updated continuously as long as I run the program. It's basically output from x number of sensors.
However, the type and number of sensors are not fixed. For example, I might be reading data from a single temperature sensor or 2 humidity sensor at a given instance. hence, I would like my LabVIEW program to recognize this and dynamically change the UI (Graph, Numerical Indicators).
To recognize the type of sensor, I am reading the device ID of the sensor, comparing it with a constant number and then printing whether it is a temperature or humidity sensor. For the number of sensors, I am reading the array size and determining the number of sensors from number of columns.
The problem arises when I try to plot the graph. Please have a look at the attached screenshots.
When i read one sensor, i want the graph to plot value from one sensor. when, i read 2 sensors, i want the graph to dynamically plot values of 2 sensors. However, i'm not able to do it.
If I am missing any basic logic behind it, please bear with me. I am beginner with LabVIEW.
Can anyone help me with this?
Thanks in advance.
VigViv
(2,607 Views)
Can you send your VIs? You told that you are receiving data from the Arduino, but I can't see how you do that.
Also I will be thankful if you can describe the logic of VI (for example using the comments).
Thank you in advance.
(2,583 Views)
Hi VigViv,
We still cannot debug images using LabVIEW.
When you need real help then you should attach your VI.
(2,580 Views)
Hi hovo90,
Apologies for the late reply. Arduino sends data to PC through serial port and I am using NI VISA to read this data from serial port. My block diagram is messy as i have not yet decided on certain algorithms yet. I am still working on them. once I am done with it, i will clean it and put labels.
and yes, i will attach the program below.
regards,
VigViv
(2,546 Views)
Hi GerdW,
Apologies for the late reply. I think I found the solution. however, I am attaching a sample program and open to other ideas / solutions if it makes my life easier. Should i use case structure to dynamically add more array splitters? I need to split the 2D array as many times the number of columns in it. and then i need to plot a graph with n-1 columns. (1st column indicates the sensor type and doesn't needed to plotted.
regards,
VigViv
(2,539 Views)
Hi VigViv,
Using a case structure to handle an unknown number of entries is nonsense: use a loop to handle more than one array element!
In the snippet I used a Map to store your unknown number of sensor data (ID+value) entries:
It's the first time I used a Map ever - so check for errors on your own!
But the basic principle stays the same: each sensorID makes a new map entry, where you add the new data value (aka sample) to the array. Then you can read all map elements to create plots using a loop…
(2,532 Views)
Hi GerdW,
Thanks for your reply. I'll look into it.
regards,
VigViv
(2,523 Views)
