Dynamically set array size
Hi everybody!
I have an array of cluster (each cluster contains 4 values) and depending on user interactions, new clusters are added to the array. I'd like to implement a "Clear" button which deletes all the elements inside the array but I can't find a solution so far. The best I can do is to set all the cluster elements to 0 but the cluster itself is still in the array.
Does anybody know how to do that?
Many thanks,
Julien
Message 1 of 8
(4,993 Views)
I would assume delete array subset will do it.
Something like this:
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 2 of 8
(4,991 Views)
Accepted by topic author jfcors
Hi jfcors,
the cluster has to stay in the array as it defines the datatype of the array.
You also seem to mis-understand the term "empty array": an array is empty when there are no elements in it!
Snippet:
@aCe:
Your example only deletes one element in an array, but not the whole array! Sorry, it's correct...
Message 3 of 8
(4,990 Views)
@GerdW: It does delete everything. Smiley Happy See array length wired to the length input.
Message 4 of 8
(4,984 Views)
Thanks a lot!
Indeed it wasn't clear. What I wanted is to remove all the elements of the array, except the first one so that the array type is still defined.
About your solution:  you show two ways to do it right? What are the names of the subvis you use? I couldn't find them in the Array palette.
Cheers,
Julien
Message 5 of 8
(4,978 Views)
@jfcors wrote:
Thanks a lot!
The array type is also defined if the array is empty. No need to keep one element for that.
Message 6 of 8
(4,975 Views)
Hi jfcors,
IndexArray, InitArray and ReshapeArray. All to be found on the Array functions palette...
And the picture is a snippet. You can download and put it in your block diagram.
There's a context help entry for snippets. Ever considered to read the help?
Message 7 of 8
(4,972 Views)
Thanks for your help, it works perfectly.
I read the help all the time, but sometimes it is easier to ask for help directly.
Bests,
Julien
Message 8 of 8
(4,966 Views)
