E-card
I ma using NI card (PCI -MIO-16 E -4 ) . iwant to know what is max possible sampling frequency of this card.
(3,306 Views)
Hi
Go to NI Web-Site and search for "PCI-6040E". It's the same card.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,301 Views)
Hi there,
Here is the data sheet for all E-series devices, this will tell you the Maximum sampling rate of the boards.
http://www.ni.com/pdf/products/us/4daqsc199-201_ETC_212-213.pdf
Also, if you look at the E-series help documentation which can be found at the link below, this will give you more detailed specifications for each board in the range, including the PCI-MIO-16E-4.
https://www.ni.com/docs/en-US/bundle/370503k/resource/370503k.pdf
Hope this helps
Hannah
NIUK & Ireland
(3,273 Views)
thanks for the reply i check the site and found that maximum sampling rate for my NI card is 500 KS/s this time iwant to know what is KS/s and with this sampling rate is what could be maximum possible scan rate like if  iam doing 1000 scan /secon this mean a sampling frequecny of 1  HZ is it possible to make  1 kHz samplingfrequency with this maximum samping rate of 500 kS/s
(3,268 Views)
Check out this site: http://zone.ni.com/devzone/conceptd.nsf/webmain/4A11BB9897245869862568430077EA82
It explains the basics about the sample rate.
Thomas
Using LV8.0
(3,264 Views)
