09-07-2005 08:19 AM
09-08-2005 04:23 PM
Caroline,
I can't find any information on this particular error, but what version of LabVIEW are you using? It must be a very old version and an upgrade may be in order. Also, what is this executable doing and does the VI that this executable was built from give any errors?
09-08-2005 08:41 PM
Hi Caroline,
I'm sure you've considered this but your post begs the question: what's changed since 2000? The problem sounds intermittent, could be hardware going bad - can you test the RAM? Do you have (the luxury of) another PXI chassis/controller to temporarily test with? In general, have there been any changes to the software environment like changes in MAX, or to the OS?. Any new software running beside the test-app? Any new/replaced PXI devices?
Cheers
09-09-2005 02:13 PM
hi
Well, I forgot to say that we have 3 other setups, exact copy of the one which is going badly. We are running on labview 5.0.
As a matter of fact, we have try changing the computer block with another, and (cross finger) everything seems ok (it is running since yesterday and no error yet). We will try on the "defect" computer block on the spare chassis and look if anything else appears, or if it's ok.
Thanks for your time
Caroline
