E3631 power supply output configuration
Can I obtain outputs from both +6V and +25V  terminals of a E3631 power supply simultaneously?
(2,877 Views)
why not?
If in doubt, READ the manual.
(2,874 Views)
Thanks nyc for replying..
I did go through the manual...but could not find a way to implement it...Can you please tell me how can I use labview driver to do the same?
(2,870 Views)
I rarely use LabVIEW drivers.
If this isn't available in the driver, you will have to write your own VI.
(2,859 Views)
Using different outputs has nothing to do with LabVIEW or any other programming language. It is a triple output power supply and there are serarate outputs right on the front panel. To use them at the same time, you have to just connect them and turn them on.
If you really mean how to program the outputs, then you must not have looked at any of the driver functions or the manual. You program the output with the Configure Output function. The help for the function is very clear about that.
(2,849 Views)
