Dennis,
I'm having a lot of trouble with it, or at least the sample vi, "...Configure and Query Marker.vi", that was included with the download.
When I first executed the vi, it failed, returning error code 1074000000, instrument reports data out of range. I "fixed" that by connecting a value, I choose the start frequency value, to the X(0) input of the Configure Marker sub vi. Now the Configure and Query Marker.vi executes, but it returns incorrect values for both the X and Y values of the marker. With an approximately -20 dBm tone inputted into the spectrum analyzer, the Marker Position output in the vi reads the start frequency, and the Y position reads 0. The input frequency is place in the middle between the start and stop frequencies.
If I individually execute the sub vi's the Marker Search.vi correctly positions the marker on the peak, and the Query Marker.vi correctly outputs the marker's frequency and amplitude. But, if I run the entire vi again, the outputs are incorrect.
Since LabVIEW has been revised at leaast twice since the version 8.0 was installed on the laptop I'm using, and the drive was copyrighted in 2007, I thought I'd ask the simple question first.
Mark
